0.85 MacOS: Skip all stops the import completely
Sander
Post by Sander »
When importing files from a SD card and duplicates are detected, I click the Skip All button. The program then tells me the import has finished.
But in fact it did not copy any files.
Expected behaviour: when clicking Skip All, it skips all duplicates instead of skipping the entire import operation.
Re: 0.85 macOS: Skip all stops the import completely
you can reproduce each time, i've tested and the copy continue after
