PDF to SVG
jesperg
PDF to SVG
Post by jesperg »
Hi
Is it possible to convert PDF to SVG format using NConvert.exe file?
regards
Jesper G
Re: PDF to SVG
jesperg wrote:Is it possible to convert PDF to SVG format using NConvert.exe file?
The NConvert Help file lists supported formats at the end, and if I'm interpreting it correctly indicates formats that are supported for writing as well as reading with an asterix.
Sadly the SVG format is only shown as supported for reading... :(
jesperg
Re: PDF to SVG
Post by jesperg »
Thanks...
Do you know any other vector format that can be used on websites, that I can convert pdf into?
Re: PDF to SVG
jesperg wrote:Do you know any other vector format that can be used on websites, that I can convert pdf into?
Not myself, although Postscript is supported for writing and might be a possibility??
XnTriq will know if anyone knows, but not until later...
Re: PDF to SVG
Welcome to the forum, jesperg.
Vector-to-vector (PDF/SVG) conversion can't be done with nConvert.
Of course there are plug-ins for DWG/DXF, PDF, SWF (FlashPaper) etc., but SVG is the only vector format supported by all modern web browsers out of the box, as far as I know.
