.tiff file conversion not happening properly.
punith8626
Post by punith8626 »
Hi
I have a tiff files in one folder where i need to generate thumbs for those multi tiff file.
Some TIFF files having extension .tif and some have .tiff
When I try to execute below command
nconvert  -out  png -resize 87 112  -xall -o C:\thumbs\%.png C:\tiff\*.tif
It will convert both .tiff and .tif files in windows server 2008 but in case of windows server 2012 it will convert only for .tif files
Is there any setup needs to be done for server 2012 so that same command works for both .tif and .tiff files ?
Re: .tiff file conversion not happening properly.
punith8626 wrote: I have tiff files in one folder where I need to generate thumbs for those multi tiff file.
Some TIFF files have extension .tif and some have .tiff
When I try to execute this command:
It converts both .tiff and .tif files in windows server 2008, but in windows server 2012 it will convert only for .tif files.
I can't answer your question regarding Windows Server 2012, and I don't know if anyone on the forum is likely to be able to, but there may be a simple work-around you can use.
NConvert accepts multiple inputs listed at the end of the command line, so you might test this code:
nconvert  -out  png -resize 87 112  -xall -o C:\thumbs\%.png C:\tiff\*.tif C:\tiff\*.tiff
Edit:
The NConvert help file only lists .tiff as a supported file format, although .tif works in my tests on Windows 7... :?:
strange that it works, and if you use *.tif*?
xnview wrote:strange that it works, and if you use *.tif*?
Not possible - error message: "A filename can't contain any of the following characters... * "
A similar situation for .jpg and .jpeg ?
in this case *.tiff *.tif
