Hello again.
I use windows 10 as my standard OS.
Since I don't like OneDrive, I configured it so it doesn't load on Windows startup.
However, every time I open XnviewMP (0.86), OneDrive loads on the program startup.
How do I disable this?.. or Is it a bug?
It didn't happen when I used 0.85...
OneDrive loads on XnviewMP start..
Re: OneDrive loads on XnviewMP start..
how do you see that OneDrive is loaded by XnViewMP?
rfrank
Because when i open XnviewMP, the tray icon appears and the setup for OneDrive opens as well
Before XnviewMP is loaded After XnviewMP loads Maybe is something web related?
Now that you've provided more detail, I think this could be related to this recently reported Windows 10 Creators Update issue:
Disable the annoying Set up OneDrive popup on Windows 10
