2.40 Hang on mixed content
sadcat
Post by sadcat »
Hello. I have small bug.
If Tools/Options/General/Keyboad mouse/Mouse wheel selected Previous/next
then If movie browsed and i scrolled wheel - program hang on next image.
If i use keyboard (PgUp, PgDn) - there is no such error. All works ok.
I have attached video https://youtu.be/OCETzYn6FE8
Win10 x64 KLMCP 12.2.2 Basic installed
Re: 2.40 Hang on mixed content
I can't reproduce, which format of video?
sadcat
Post by sadcat »
No difference, which videoformat. For example https://yadi.sk/i/RYa2xca-3JBPEq
Please, follow next steps: jpg--[wheel]--jpg--[wheel]--video--[wheel down]--hanging....
If i use screen buttons or keyboard keys - all works fine. Only mouse wheel moving calls hanging.
on my win8.1, no hang, i'll try on win10
jossbou
Post by jossbou »
Hi all,
it seems I do have the same problem on a folder mixing jpg and mov files (all coming from my Fuji XS1). When I add the raw files (raf format) to the jpg, I can open jpg files or rotate them on Exif. When I add the mov files, Xnview hangs on opening jpg or rotating. Sometimes it works with less mov files, but with the 8 ones coming from the same session, it hangs. Xnview 2.40. Windows seven up to date.
