Hi!
I downloaded the plugin "IlmImf.dll" to open the exr files in Xnview.
I put that dll in the plugins directory.
It doesn't work. I don't see any thumbnail in xnview for exr files.
If I doubleclick the thumbnails it says "I cannot read the file".
Also I don't find the exr extension in the list of extensions in the preferences.
Is there another way to see exr in xnview?
TIA
I cannot see exr files. Even with the plugin
Re: I cannot see exr files. Even with the plugin
the plugin used is no more IlmImf.dll but OpenEXR.dll (Extended package)
jeeg
Oh! Sorry.
I will look for it.
Ok! I download and installed the "complete version".
Now I can see the ext too! Thank you again.
I will look for it.
