Unable open .tif files
V@no
Post by V@no »
Hello.
Trying open .tif files from https://www.boem.gov/Gulf-of-Mexico-Dee ... athymetry/ shows
Error opening the file <BOEMbathyE_m.tif>
Any ideas?
Thank you.
Windows 10 x64
XnView v2.40 Extended
Re: Unable open .tif files
Looking at the file size of the TIFFs on the page you link to, a possible reason that they can't be opened might be that their pixel dimensions when opened require more ram than can be addressed by a 32-bit Windows application.
You might try again using the XnView MP 64-bit version...
it's a BigTIFF format, not supported by XnView
V@no
Post by V@no »
xnview wrote:it's a BigTIFF format, not supported by XnView
Oh, any chances one day it will be supported in non-mp xnview?
