"XnConvert.app can’t be opened. You should move it to the Trash." message
richardpbull
Post by richardpbull »
GREETINGS.
I just upgraded to 1.74 and get this error. I tried using 1.73 and get the same error. The previous version worked fine though cannot remember the version number.
This is the error message:
https://www.dropbox.com/s/h42srgbgdlzeh ... 0.png?dl=0
I've only found one similar answer on the web and tried this with no success.
https://apple.stackexchange.com/questio ... r-applicat
Any clues?
Thanks a lot,
Richard
richardpbull
Re: XnConvert.app can’t be opened. You should move it to the Trash.
If I drag .../XnConvert.app/Contents/MacOS/XnConvert itself into terminal window to run the app, it works. Just not from double clicking the app icon
richardpbull wrote:If I drag .../XnConvert.app/Contents/MacOS/XnConvert itself into terminal window to run the app, it works. Just not from double clicking the app icon
and no problem with XnViewMP?
richardpbull
xnview wrote:and no problem with XnViewMP?
No, just downloaded it, it works fine.
FCP
Re: "XnConvert.app can’t be opened. You should move it to the Trash." message
Post by FCP »
I am getting this same error too :/
tyres
Post by tyres »
Hi
Got the same error too... (Yosemite)
I’ve found a way to make it work:
in terminal:
sudo bash
**enter password**
xattr -cr /Applications/XnConvert.app
sorry but i'll release new version in 1 week
