Hi
Firstly I'd just like to say XNView is an absolutely brilliant util!
Anyway I've finally downloaded the latest version (I had been using a version from 2004). However for some reason I can't see anyway to write files in Degas Elite (PI1) format now.
Any ideas ? I'm sure I'm doing something stupid!
Shw
Degas Elite PI1 format
Check if the 'Options / General / Startup => Use all formats available' option is cheked.
Showaddywaddy
