I'm new on the forum.
I tried to install XnConvert rpm package, but it causes errors in installation process:
"Error running transaction: file / from install of xnconvert-1.74-2.x86_64 conflicts with file from filesystem-3.2-37.fc24.x86_64
file /usr/bin from install of xnconvert-1.74-2.x86_64 conflicts with file from filesystem-3.2-37.fc24.x86_64"
I tried the solution of rebuild package with rpmrebuild, but it doesn't work... Is there any solution to this problem?
Thanks in advance to all.
XnConvert impossible to install on Fedora 25
Re: XnConvert impossible to install on Fedora 25
and the tgz works?
junker
I could't get it working...xnview wrote:and the tgz works?
what do you have when starting it?junker wrote:I could't get it working...xnview wrote:and the tgz works?
junker
The software doesn't start...
but in the console?junker wrote:The software doesn't start...
junker
It doesn't start anyway.xnview wrote:but in the console?junker wrote:The software doesn't start...
if you start ./xnconvert.sh from a console, what do you have?
junker
It works... but when I try to install it from terminal, it says that it needs a XCB plugin. I already have it installed... It also said that it impossible to give ./configure command because it doesn't exist a configure file. I wanted to give ./configure make make install.
junker
On Fedora 27 same problem: it is impossible to install XnConvert...
