Old versions of XnView software
bdragon
Could you put previous versions of Xnview (or any other) too up on your site? It might help to diagnose some problems, if they are due to the latest versions or if they are a problem of the machine using it. At this momen, (unless i am mistaken) the only way to get an old version is to seek it from download sites and most of them seem shady.
Re: Old versions of XnView software
Previous versions of XnView software have long been available although not easy to find, you can download them from the following location:bdragon wrote:Could you put previous versions of Xnview (or any other) too up on your site? It might help to diagnose some problems, if they are due to the latest versions or if they are a problem of the machine using it. At this moment, (unless I am mistaken) the only way to get an old version is to seek it from download sites and most of them seem shady.
http://download.xnview.com/old_versions/
bdragon
Thanks. Will do.
