"Save as" in view mode overwrites without asking
KRH
I don't how long it's been going on, but when I try to save an image in view mode in v. 1.80.3 as a separate image with a different name, whether I've edited it or not, if there is an existing file in the same folder with the same name, it automatically gets overwritten. There doesn't seem to be anything I can do about it. Going through the options menu, I don't see any relevant settings that I can change..
Re: "save as" in view mode overwrites without aski
Strange you should have a warning box when you select the new name in file/save as dialog...KRH wrote:I don't how long it's been going on, but when I try to save an image in view mode in v. 1.80.3 as a separate image with a different name, whether I've edited it or not, if there is an existing file in the same folder with the same name, it automatically gets overwritten. There doesn't seem to be anything I can do about it. Going through the options menu, I don't see any relevant settings that I can change..
KRH
KRH
I uninstalled, removed all associated files, cleaned the Windows registry, and reinstalled, but the problem persists.
Just to make sure my problem is clearly stated, here's what happens: Say, I open 1a.jpg from folder X, then I crop the image and save it as 1b. If there's already a 1b.jpg in that folder, it's silently overwritten.
Win98SE
You use File/Save as, right?KRH wrote:I uninstalled, removed all associated files, cleaned the Windows registry, and reinstalled, but the problem persists.
KRH
I get the same result whether I use File/Save as or use the "Save as" button on the tool bar. I did, however, just now make a discovery: If I save the file to a folder other than the one from which I opened the original file (that is, folder y rather than folder x) and there is an existing file in that other folder with the same name, I do get a warning.
Win98SE
KRH
I have to revise that. What's really happening is that, no matter where I save the file, if I save it without an extension, it overwrites an existing file, but if I add the extension, it warns. Is that the default behavior? I'm sure it wasn't like that in v. 1.74.KRH wrote: I did, however, just now make a discovery: If I save the file to a folder other than the one from which I opened the original file (that is, folder y rather than folder x) and there is an existing file in that other folder with the same name, I do get a warning.
Win98SE
marsh
Confirmed on Win2K. It overwrites without warning if you don't have extension displayed in name box and if extension is automatically added. Example: "1" overwrites "1.jpg" in same directory with no warning box.KRH wrote:I have to revise that. What's really happening is that, no matter where I save the file, if I save it without an extension, it overwrites an existing file, but if I add the extension, it warns. Is that the default behavior? I'm sure it wasn't like that in v. 1.74.KRH wrote: I did, however, just now make a discovery: If I save the file to a folder other than the one from which I opened the original file (that is, folder y rather than folder x) and there is an existing file in that other folder with the same name, I do get a warning.
KRH
That is the behavior I'm experiencing but I don't have Win2k, I have Win98SE.marsh wrote:Confirmed on Win2K. It overwrites without warning if you don't have extension displayed in name box and if extension is automatically added. Example: "1" overwrites "1.jpg" in same directory with no warning box.
Win98SE
Ok, right a bug, but same as 1.74!KRH wrote:I have to revise that. What's really happening is that, no matter where I save the file, if I save it without an extension, it overwrites an existing file, but if I add the extension, it warns. Is that the default behavior? I'm sure it wasn't like that in v. 1.74.KRH wrote: I did, however, just now make a discovery: If I save the file to a folder other than the one from which I opened the original file (that is, folder y rather than folder x) and there is an existing file in that other folder with the same name, I do get a warning.
KRH
I've just added this one to the list of must fixes. Think no user should ever happen to overwrite a file.
KRH
Dreamer
