0.86 (Mac): Click and drag copies instead of moves
trevzilla
Post by trevzilla »
XnView: MP 0.86 - 64 bit
OS: Mac 64bit
When clicking and dragging images from the browser window to the file tree, the images are copied to the new location instead of moved there, even though the new location is on the same physical drive.
Effect: Must delete photos from original location, adding an extra step.
1. Select files from browser window
2. Click and drag selected file to a new directory in the folder tree (on the same physical drive)
3. Drop files in new directory.
Actual behaviour (bug): Files are copied.
Expected behaviour: Files should be moved.
(I reported this same behavior a while ago with the PC version, and it was fixed in version 0.86. But it seems the same bug exists on the Mac version still)
Re: 0.86 (Mac): Click and drag copies instead of moves
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
trevzilla
Post by trevzilla »
It appears that the bug is fixed. Thanks!
