After manually rearranging file sort order in browser mode the changes are not reflected in viewer mode (ie when navigating in viewer mode using arrow keys, or previous/next in toolbar)
[In fullscreen mode the changes are reflected]
However, after closing the instance of XnViewMP, and reopening then the sort order in viewer mode will then match that manually set in browser.
Solution - make sure browser mode uses most recently set sort order.
Custom sort in view mode [minor]
Re: Custom sort in view mode [minor]
You need to close the view mode, and reopen it to apply changes
