I'm a new user exploring the cataloguing capabilities of xnviewmp.
I've just clicked on category "friends" for a given image and
checked that I can filter using this category.
Nevertheless, I visualize the XMP window and do not see the category anywhere.
Where is this information being actually written? It is important in terms of
compatibility
Also, I've seen there is an option "update or create XMP sidecar" in Settings/Metadata
If this option is selected, would the "category" information be saved to the sidecar file only
or would it be written to the jpg or or tif file as well? I would prefer saving the information
into both files (unless you think this could cause problems).
Thanks
Agus
Where are "categories" written?
Re: Where are "categories" written?
Depeding on settings>Metadata. By default categories are written in the catalog of XnView, but you can write them in the file itself or sidecaralobo wrote:I'm a new user exploring the cataloguing capabilities of xnviewmp.
compatibility
it will be saved in the sidecarAlso, I've seen there is an option "update or create XMP sidecar" in Settings/Metadata
alobo
This is how I have my settings
(https://drive.google.com/open?id=0B_LsZ ... 1I3M3hqWnc)
(everything selected except the sidecar)
but still do not see the info in the XMP
(https://drive.google.com/open?id=0B_LsZ ... mxZdC1WaU0)
where is the xnview DB file? which type of db is it?
Thanks
Thanks
And when you add a category on jpeg file, no XMP categories??alobo wrote:This is how I have my settings
In Settings>Integration>Paths, you have 'open catalog location'where is the xnview DB file? which type of db is it?
alobo
I might have a misunderstanding here:
Do I have to select and then "add"? In that case, how do I "add" the comment?
(there is no user manual or tutorial, is it?)
Regarding the db
Thanks
I thought that just by selecting a given "Category", i.e., "Friends", the comment was automatically added.And when you add a category on jpeg file, no XMP categories??
Regarding the db
what kind of db is it? does it use open source software (i.e., mysql or PostgreSQL) ?In Settings>Integration>Paths, you have 'open catalog location'
Thanks
If you select a category, it will be added in XMP metadataalobo wrote: I thought that just by selecting a given "Category", i.e., "Friends", the comment was automatically added.
SQLitewhat kind of db is it? does it use open source software (i.e., mysql or PostgreSQL) ?
alobo
I do not understand. Then, why don't I see it in the XMP? "Friends" is selected but not present in the XMPIf you select a category, it will be added in XMP metadata
https://drive.google.com/file/d/0B_LsZU ... 1WaU0/view
how do add a category? Via category panel? on jpeg file, right?alobo wrote:I do not understand. Then, why don't I see it in the XMP? "Friends" is selected but not present in the XMP
alobo
did not understand your questions but anyway it works now:
https://drive.google.com/open?id=0B_LsZ ... Ek5eTloQzA
Problem solved then
Problem solved then
