Hi i have found a bug when deleting a picture file with XnView 1.68.1 if a pdf file is in the directory.
For that i have enabled at options, category "Misc.":
Maximize XnView at Startup
Remember last window position/size
Only one Instance
Delete to Recycle Bin
Confirm file delete
Enable BMP Animation
Use XP style menus
Options, Category "View":
Maximize view when Open
Fit image to window, all
Adjust zoom if X/Y DPI are diferent
and English language.
Open a picture file with a pdf file on that directory, that picture file must be the only on that directory, and XnView get hanged.
I have tried on my Pentium III with Windows XP SP 2 beta 2055 with the same problem, and another 4 friends with more Windows XP can see that bug.
XnView stalls when deleting file with PDF file in directory
Aokromes
Re: XnView stalls when deleting file with PDF file in direct
Hi, ok i'll check.Aokromes wrote:Hi i have found a bug when deleting a picture file with XnView 1.68.1 if a pdf file is in the directory.
