I use XnViewMP 0.86 on a Win7 System.
The panel IPTC-IIM/XMP -> Date/Time reads the date value for "Created date/time" correctly from metadata stored inside an image file.
But the time value is always set to 00:00. See attached screenshot.
This is very annoying because in case of only modifying one value and not taking care of date/time, time is reset to 00:00.
On the other hand it would be very helpful to allow also to enter seconds to the time value.
Best regards
Herb
Edit IPTC-IIM/XMP -> Date/Time
herb
Re: Edit IPTC-IIM/XMP -> Date/Time
could you send me a test file?
herb
Hello Pierre,
thanks for your investigations.
Image is sent via mail, because of size.
Best regards
Herb
Best regards
Herb
will be fixed in next version
herb
Hello Pierre,
thanks for the correction.
But please allow an additional comment: I looked again into the IPTC (and also XMP) standard and have seen that both request also a timezone value for time tags.
It would be wonderful if that would also be possible.
Best regards
Herb
Best regards
Herb
ok, but please make a post in suggestion
