jpg to cad conversion
Post by Guest »
Is it possible to go from jpg to cad? I keep getting bad out format.
Re: jpg to cad conversion
Anonymous wrote:Is it possible to go from jpg to cad? I keep getting bad out format.
No sorry
A JPG file is a bitmap consisting of pixels, whereas a CAD file is a vector based image, consisting of lines, circles and other shapes. Converting from a CAD file to JPG is pretty difficult, already. The other way round is impossible. There's tools like Corel Trace for example which try conversion from bitmaps to vector graphic, but the results are soso - depending on what you want.
Post by Guest »
Well I know its possible cause I use software that does it, I;m just trying to figure out how. :)
