0.86: Can't input Chinese with ibus-chewing in XnViewMP(Linux DEB 64bit version)
pogaso
Post by pogaso »
Here is my software environment:
XnViewMP version: 0.86
OS: Linux Mint 17.3 Cinnamon 64-bit
Linux kernel: 3.19.0-32-generic
Cinnamon version: 2.8.8
IBus version: 1.5.5
IBus chinese input method: ibus-chewing
We have some problem that use LINUX version of the XnViewMP can not use iBUS input Chinese to rename the files. How to solve it ? :?:
By the way, I had installed ibus-qt kit, but it still not working... :|
Thanks~~!! :)
ibus-qt kit:
apt-get installed:
libibus-qt-dev
ibus-qt4
build-essential
cmake
libx11-dev
qt-sdk
libicu-dev
libdbus-1-dev
libdbus-glib-1-dev
doxygen
source code installed:
ibus-qt: https://github.com/ibus/ibus-qt
1. install input method framework & ibus-chewing.
sudo apt-get install -y ibus-table ibus-chewing ibus-clutter ibus-gtk ibus-gtk3 ibus-qt4
im-config -n ibus
2. Setting ibus to use ibus-chewing.
3. Use XnViewMP to change the file name, and input Chinese with ibus-chewing.
Actual behaviour (bug): When change file name in XnViewMP, Can't use ibus-chewing to input Chinese.
Expected behaviour : When change file name in XnViewMP, Can use ibus-chewing to input Chinese.
