Batch conversion can't get to work
Post by Guest »
Alright, I've search the forum and will start gonit through. I have two issues.
I'm need to conver all the files in a directory from Tif to BMP. I'm trying this commend line:
Nconvert -out bmp *.tif
But it keeps saying "Error: Can't open file (*.tif). Why doesn't this wildcard work?
And two. When I put in "nconvert -help" it scolls through too fast. Is there a page command I can add?
Thanks
Damon
Post by Guest »
Forgot, I'd also like to delete the original after converting. Is that possible?
Re: Batch conversion can't get to work
Anonymous wrote:Alright, I've search the forum and will start gonit through. I have two issues.
Strange wildcard works, i've just checked
Try nconvert -help | more
Anonymous wrote:Forgot, I'd also like to delete the original after converting. Is that possible?
-D
Post by Guest »
Got the wildcard to work. Had to upgrade. but the more command, it doesn't recognize. Is there another location I can get a list of the -help?
Thanks
Post by Guest »
"-d" didn't work
Nconvert -d -out bmp *.tif
and tried
nconvert -out bmp *.tif -d
Anonymous wrote:Got the wildcard to work. Had to upgrade. but the more command, it doesn't recognize. Is there another location I can get a list of the -help?
Which OS do you have?
Anonymous wrote:"-d" didn't work
and tried
Not -d but -D
