[Solved] Crop tool - Cannot adjust selection size
machuca
Post by machuca »
XnView MP Windows
Version 0.86 64bits (Apr 25 2017)
My system: Win10 Pro 64 bit
When I try to crop free, there isn't any window for croping. I tried to do it using the box above, for example a quadrat of 100 x 100 pix. The window apear. Trying to increase it, but this isn't possible. I put the grabber and than I can see the dobble arrow, but I cannot increase or decrease the window. Is fixed.
Croping is very basical, so please help. In the moment I use the old xnview for this...
Re: cannot crop free
Use mouse to draw your selection to crop it, like XnView Classic
machuca
Post by machuca »
I cannot use the mouse, it doesn't work. There is no rectangel. I can use the fixed windows, but when I try to change this windows - to make it greater or smaler, it isn't possible although, its fixed. Sorry, I have no idea, why, but without cropping...
Any idea?
machuca wrote:I cannot use the mouse, it doesn't work. There is no rectangle. I can use the fixed windows, but when I try to change this windows - to make it greater or smaler, it isn't possible although, its fixed. Sorry, I have no idea, why, but without cropping...
Any idea?
You are really working without a mouse and can't obtain another, or is that a misunderstanding??
machuca
Post by machuca »
I understand, that you can believe, but I use your programm since years and yes, its in the moment not possible.
I made a film with a screenrecorder: http://www.fotomesh.de/tmp/cannotcut.webm
The files aren't writeprotected or special formated, only jpgs...
You are the first user with this problem...
what do you have in Settings>Interface? And if you don't use the Crop toolbar?
machuca
Post by machuca »
I hope that there aren't many others... :wink:
OK here my settings:
and when I try to edit directly the zoom of the picture start:
http://www.fotomesh.de/tmp/cropping2.webm
Edit:
just found that I can crop with the left mousebutton + ctrl!
Thats the first way!
But I cannot change the window :(
machuca wrote:
I just found that I can crop with the left mouse button + ctrl!
Good that you have now a useable workaround! :D
You might look at this setting which is possibly the reason that you are unable to change the selection size when using the Crop tool... :?:
Re: Crop tool - Cannot adjust selection size
Regarding settings:
If you are able to discover a setting or combination of settings that causes the problem you described with the Crop tool, it could help Pierre identify a possible previously unreported bug...
machuca
Post by machuca »
It works!
I changed the value of the mouse left button in Interface/Mouse from "Move picture" to "Make selection" and now all is OK!
It works although inside the crop tool, and I can now change the window. Perfect.
Thanks a lot for the fast help and for the great programm of course!
Re: [Solved] Crop tool - Cannot adjust selection size
Please see this new thread:
When selections can't be modified
