Suppressing Ghostscript text output when opening PDFs
zoosy
Post by zoosy »
Hi all,
I'm converting some PDFs to binary PNG using NConvert in Linux (CentOS 6.8 x64 / NConvert v6.88 / GS v8.70).
On every run, I get the help from ghostscript in the output (even if -quiet mode is enabled in NConvert... seems that it is not passing -quiet to ghostscript too):
/opt/nconvert/nconvert -quiet -xall -dpi 300 -binary floyd -out png -o 0000-####.png 0000.pdf
where 0000.pdf is a 30 page PDF file
The output looks like this:
** NCONVERT v6.88 (c) 1991-2016 Pierre-E Gougelet (May  1 2016/09:41:37) **
        Version for Linux x86 (X11)  (All rights reserved)
** This is freeware software (for non-commercial use)
GPL Ghostscript 8.70 (2009-07-31)
Copyright (C) 2009 Artifex Software, Inc.  All rights reserved.
Usage: gs [switches] [file1.ps file2.ps ...]
Most frequently used switches: (you can use # in place of =)
 -dNOPAUSE           no pause after page   | -q       `quiet', fewer messages
 -g<width>x<height>  page size in pixels   | -r<res>  pixels/inch resolution
 -sDEVICE=<devname>  select device         | -dBATCH  exit after last file
 -sOutputFile=<file> select output file: - for stdout, |command for pipe,
                                         embed %d or %ld for page #
Input formats: PostScript PostScriptLevel1 PostScriptLevel2 PostScriptLevel3 PDF
Default output device: x11alpha
Available devices:
   alc1900 alc2000 alc4000 alc4100 alc8500 alc8600 alc9100 ap3250 appledmp
   atx23 atx24 atx38 bbox bit bitcmyk bitrgb bitrgbtags bj10e bj10v bj10vh
   bj200 bjc600 bjc800 bjc880j bjccmyk bjccolor bjcgray bjcmono bmp16 bmp16m
   bmp256 bmp32b bmpgray bmpmono bmpsep1 bmpsep8 cairo ccr cdeskjet cdj1600
   cdj500 cdj550 cdj670 cdj850 cdj880 cdj890 cdj970 cdjcolor cdjmono cdnj500
   cfax cgm24 cgm8 cgmmono chp2200 cif cljet5 cljet5c cljet5pr coslw2p
   coslwxl cp50 cups declj250 deskjet devicen dfaxhigh dfaxlow display
   dj505j djet500 djet500c dl2100 dnj650c epl2050 epl2050p epl2120 epl2500
   epl2750 epl5800 epl5900 epl6100 epl6200 eplcolor eplmono eps9high eps9mid
   epson epsonc epswrite escp escpage faxg3 faxg32d faxg4 fmlbp fmpr fs600
   gdi hl1240 hl1250 hl7x0 hpdj1120c hpdj310 hpdj320 hpdj340 hpdj400 hpdj500
   hpdj500c hpdj510 hpdj520 hpdj540 hpdj550c hpdj560c hpdj600 hpdj660c
   hpdj670c hpdj680c hpdj690c hpdj850c hpdj855c hpdj870c hpdj890c hpdjplus
   hpdjportable ibmpro ijs imagen imdi inferno iwhi iwlo iwlq jetp3852 jj100
   jpeg jpegcmyk jpeggray la50 la70 la75 la75plus laserjet lbp310 lbp320
   lbp8 lex2050 lex3200 lex5700 lex7000 lips2p lips3 lips4 lips4v lj250
   lj3100sw lj4dith lj4dithp lj5gray lj5mono ljet2p ljet3 ljet3d ljet4
   ljet4d ljet4pjl ljetplus ln03 lp1800 lp1900 lp2000 lp2200 lp2400 lp2500
   lp2563 lp3000c lp7500 lp7700 lp7900 lp8000 lp8000c lp8100 lp8200c lp8300c
   lp8300f lp8400f lp8500c lp8600 lp8600f lp8700 lp8800c lp8900 lp9000b
   lp9000c lp9100 lp9200b lp9200c lp9300 lp9400 lp9500c lp9600 lp9600s
   lp9800c lps4500 lps6500 lq850 lx5000 lxm3200 lxm5700m m8510 mag16 mag256
   md1xMono md2k md50Eco md50Mono md5k mgr4 mgr8 mgrgray2 mgrgray4 mgrgray8
   mgrmono miff24 mj500c mj6000c mj700v2c mj8000c ml600 necp6 npdl nullpage
   oce9050 oki182 oki4w okiibm omni oprp opvp paintjet pam pbm pbmraw pcl3
   pcx16 pcx24b pcx256 pcx256 pcx2up pcxcmyk pcxgray pcxmono pdfwrite
   pdfwrite pgm pgmraw pgnm pgnmraw photoex picty180 pj pjetxl pjxl pjxl300
   pkm pkmraw pksm pksmraw plan9bm png16 png16 png16m png16m png256 png256
   png48 pngalpha pngalpha pnggray pnggray pngmono pngmono pnm pnmraw ppm
   ppmraw pr1000 pr1000_4 pr150 pr201 ps2write psdcmyk psdrgb psgray psmono
   psrgb pswrite pxlcolor pxlmono r4081 rinkj rpdl samsunggdi sgirgb sj48
   spotcmyk st800 stcolor sunhmono svg t4693d2 t4693d4 t4693d8 tek4696
   tiff12nc tiff24nc tiff32nc tiffcrle tiffg3 tiffg32d tiffg4 tiffgray
   tifflzw tiffpack tiffsep uniprint wtscmyk wtsimdi x11 x11alpha x11cmyk
   x11cmyk2 x11cmyk4 x11cmyk8 x11gray2 x11gray4 x11mono xcf xes
Search path:
   /usr/share/ghostscript/8.70/Resource/Init :
   /usr/share/ghostscript/8.70/lib :
   /usr/share/ghostscript/8.70/Resource/Font :
   /usr/share/ghostscript/fonts : /usr/share/fonts/default/ghostscript :
   /usr/share/fonts/default/Type1 : /usr/share/fonts/default/amspsfnt/pfb :
   /usr/share/fonts/default/cmpsfont/pfb : /usr/share/fonts :
   /usr/share/ghostscript/conf.d : /etc/ghostscript : /etc/ghostscript/8.70
For more information, see /usr/share/ghostscript/8.70/doc/Use.htm.
Please report bugs to bugs.ghostscript.com.
Available devices:
Search path:
A Portable Document Format (RGB) was recognized : 0000.pdf
    Width:2553 Height:3503 with 16777216 colors
    Nplanes : 1      Bitscount : 24
    Bytes Per Plane : 7659
    xdpi : 300         ydpi : 300
Converting in Binary : OK
Conversion of 0000.pdf into 0000-0001-0.png OK
Available devices:
Search path:
Available devices:
Search path:
    Width:2482 Height:3503 with 16777216 colors
    Bytes Per Plane : 7446
... and so on.
My question is: How can I suppress the ghostscript help?
It's bugging me because it's very hard to check the NConvert output.
It should look like this:
Conversion of 0000.pdf into 0000-0001-1.png OK
Re: Suppressing Ghostscript text output when opening PDFs
Although Pierre as the program designer is probably the only person who can comment on or implement a solution for the root cause of the verbose Ghostscript output you report, the following observation may be of some use:
There seemed to be a sudden increase in the text displayed possibly around two years or so ago; whether that was due to a change in Ghostscript itself, or possibly but probably less likely, a change in NConvert, I don't know.
In the absence of an early solution from Pierre, you might therefore try testing earlier versions of Ghostscript, and if necessary also earlier versions of NConvert provided all the options you need are supported...
Right, it will be removed
