XnView does not provide correct thumbnail for image
Hacker
Post by Hacker »
Hi all,
I am using XnView to show JPG file thumbnails in Total Commander. However, this image's thumbnail is not shown correctly, it's just a grey pixel.
Windows 10
XnView 2.40
TC 9.0a x64
Any thoughts, ideas or suggestions appreciated.
Roman
Re: XnView does not provide correct thumbnail for image
Hi Roman
I can't reproduce the issue, but there seems to be a problem with the embedded thumbnail in the extension segment (JFXX) to the APP0 JFIF marker: “Not known APP0 type. Skipping remainder.”
JPEGsnoop 1.7.5 by Calvin Hass
  http://www.impulseadventure.com/photo/
  Filename: [X:\test.jpg]
  Filesize: [33827] Bytes
Start Offset: 0x00000000
*** Marker: SOI (xFFD8) ***
  OFFSET: 0x00000000
*** Marker: APP0 (xFFE0) ***
  OFFSET: 0x00000002
  Length     = 16
  Identifier = [JFIF]
  version    = [1.2]
  density    = 144 x 144 DPI (dots per inch)
  thumbnail  = 0 x 0
*** Marker: APP1 (xFFE1) ***
  OFFSET: 0x00000014
  Length          = 784
  Identifier      = [Exif]
  Identifier TIFF = 0x[49492A00 08000000]
  Endian          = Intel (little)
  TAG Mark x002A  = 0x002A
  EXIF IFD0 @ Absolute 0x00000026
    Dir Length = 0x000C
    [IFD0.0x0100                         ] = 0x[00000A00] / 2560
    [IFD0.0x0101                         ] = 0x[00000600] / 1536
    [Make                                ] = "SAMSUNG"
    [Model                               ] = "GT-I8200N"
    [Orientation                         ] = 6 = Row 0: right, Col 0: top
    [XResolution                         ] = 72/1
    [YResolution                         ] = 72/1
    [ResolutionUnit                      ] = Inch
    [Software                            ] = "I8200NXXUAOC1"
    [DateTime                            ] = "2017:07:15 17:05:03"
    [YCbCrPositioning                    ] = Centered
    [ExifOffset                          ] = @ 0x00E2
    Offset to Next IFD = 0x000002B6
  EXIF IFD1 @ Absolute 0x000002D4
    Dir Length = 0x0005
    [Compression                         ] = JPEG
    [IFD1.0x0112                         ] = 6
    Offset to Next IFD = 0x00000000
  EXIF SubIFD @ Absolute 0x00000100
    Dir Length = 0x0016
    [ExposureTime                        ] = 201/65536 s
    [FNumber                             ] = F2.6
    [ExposureProgram                     ] = Aperture priority
    [ISOSpeedRatings                     ] = 50
    [ExifVersion                         ] = 02.20
    [DateTimeOriginal                    ] = "2017:07:15 17:05:03"
    [DateTimeDigitized                   ] = "2017:07:15 17:05:03"
    [ComponentsConfiguration             ] = [Y Cb Cr .]
    [ExposureBiasValue                   ] = 0.00 eV
    [MaxApertureValue                    ] = 2760/1000
    [MeteringMode                        ] = CenterWeightedAverage
    [Flash                               ] = Flash did not fire
    [FocalLength                         ] = 3 mm
    [MakerNote                           ] = @ 0x0240
    [FlashPixVersion                     ] = 01.00
    [ColorSpace                          ] = sRGB
    [ExifImageWidth                      ] = 0x[00000051] / 81
    [ExifImageHeight                     ] = 0x[00000027] / 39
    [ExposureMode                        ] = Auto exposure
    [WhiteBalance                        ] = Auto white balance
    [DigitalZoomRatio                    ] = 65536/65536
    [SceneCaptureType                    ] = Standard
  EXIF MakerIFD @ Absolute 0x0000025E
    Makernote decode option not enabled.
  OFFSET: 0x00000326
  Length     = 29597
  Identifier = [JFXX]
*** Marker: APP9 (xFFE9) ***
  OFFSET: 0x000076C5
  Length     = 4
*** Marker: DQT (xFFDB) ***
  Define a Quantization Table.
  OFFSET: 0x000076CB
  Table length = 67
  Precision=8 bits
  Destination ID=0 (Luminance)
    DQT, Row #0:   1   1   2   3   3   3   2   3
    DQT, Row #1:   1   1   3   3   1   1   5   3
    DQT, Row #2:   1   1   1   1   1   4   2   4
    DQT, Row #3:   1   1   1   1   3   1   4   7
    DQT, Row #4:   1   1   3   1   4   6   6   7
    DQT, Row #5:   2   4   1   6   6   5   6   6
    DQT, Row #6:   3   2   6   5   4   4   5   5
    DQT, Row #7:   3   4   3   4   5   5   6   5
    Approx quality factor = 96.71 (scaling=6.59 variance=15.87)
  OFFSET: 0x00007710
  Table length = 67
Hacker
Post by Hacker »
Hi XnTriq,
Not sure if that's really the case, since if I rotate the image (Rotate based on EXIF value), the thumbnail is shown fine. However, if you are right and XnView cannot use the embedded thumbnail (for any reason), I'd suggest to provide a thumbnail from the image itself.
Roman
Hacker wrote:Not sure if that's really the case, since if I rotate the image (Rotate based on EXIF value), the thumbnail is shown fine. However, if you are right and XnView cannot use the embedded thumbnail (for any reason), I'd suggest to provide a thumbnail from the image itself.
Yes, I agree.
BTW: Have you tried activating Create thumbnail from original image if embedded is smaller than thumbnail size (ToolsOptionsThumbnailsAppearance)?
Hacker
Post by Hacker »
Hello XnTriq,
XnTriq wrote:BTW: Have you tried activating Create thumbnail from original image if embedded is smaller than thumbnail size (ToolsOptionsThumbnailsAppearance)?
Yes, I have. Does not help. Does it work for you?
Roman
Sorry for the delay, Roman.
Hacker wrote:Does it work for you?
No, but I was hoping that it would work in conjunction with Total Commander. Unfortunately I don't have any hands-on experience with XnView as a plug-in for TC :-|
@Pierre: Can you reproduce the issue?
XnTriq wrote:@Pierre: Can you reproduce the issue?
No i can't reproduce, this problem is only for this picture file?
xnview wrote:No i can't reproduce, this problem is only for this picture file?
I think so. JPEGsnoop reports an error.
Hacker
Post by Hacker »
I can provide more samples if necessary. They are all taken by a cameraphone in vertical orientation.
