[Bug] Dollar signs being turned into numbers during output?
Clonkex
Post by Clonkex »
I had some filenames like this:
...and they came out like this:
This is just weird and definitely unwanted. I'll rename the images for now but it'd be great if someone could take the time fix this little bug, just for me ;)
Re: [Bug] Dollar signs being turned into numbers during output?
right currently # and $ are used for count, so perhaps a way to disable it?
Clonkex
Post by Clonkex »
Coming back to this a couple of years later, yes, a way to disable interpreting $ as a special character would be fantastic. I often have to bulk resize images named by the marketing team as things like "8x12 Canvas - RRP $49 - NOW $10a" and it's rather inconvenient that I have to manually rename them to not have the dollar signs.
sorry but i was wrong, $ is not used. Which template for filename do you use?
Clonkex
Post by Clonkex »
Actually I just realised I was still on 1.74. I took screenshots of each tab of the program before upgrading to 1.80, and after upgrading I realised what you meant by "template for filename". Using the screenshots I can confirm my filename template was just {filename}.
The good thing is, on 1.80 it seems to work correctly. Finally I can stop removing $ from files!
Thanks for all your work. XnConvert is an incredibly useful program!
EDIT: Also, the changelog link at the bottom of the XnConvert page still links to the 1.74 changelog post on the forum.
