Error MSVCR120.dll is missing on starting XnView
jgh
Having just installed XnView (2.40, new download of full version), when I start it I get an XnView.exe System error message box come up ''The program can't start because MSVCR120.dll is missing from your computer. Try reinstalling...". But when I click ok, it (XnView) does seem to start up. Neither re-installation of XnView (as suggested in the message), nor a system reboot, have cured the problem.
My system: Windows 7 Professional, 32 bit.
(Edited to correst missing file name in title)
Re: Error MSCVCR120.dll is missing on starting XnView
please try to remove plugin\openexr.dll?
jgh
Re: Error MSVCR120.dll is missing on starting XnView
How might I do that?
Looking under Info > Plug-Ins Information it does not appear in the list of either plugins or Addons; nor can I see it in C:\Program Files\XnView , or any of its subfolders; nor is it mentioned in Plugins.txt.
(But one thing I did notice was in \XnView\Addon\Microsoft.VC90.CRT\msvcr90.dll ,dated 2008)
At installation I left the list of plugins and addons as it came.
what do you have in XnView\Plugins folder?
jgh
In C:\Program Files\XnView\PlugIns :
And (in case its relevant) in C:\Program Files\XnView\Addon
with subfolders Masks & Microsoft.VC90.CRT
BMF_read.dll
bpg.txt
bpgdec.exe
CADImage.dll
CADImageLicense.txt
charls.dll
cpa.dll
CS_Manager.exe
DC120.dll
deco_32.dll
fif-license.txt
flif_license.txt
jbig2dec.exe
ldf.dll
ldf_jpm.dll
libflif.dll
libjpeg-62.dll
libmng.dll
libpng15-15.dll
lwf.dll
mpeg.dll
ncc.dll
openjp2.dll
pcdlib32.dll
rwz_sdk.dll
slide.exe
VTFLib.dll
WaveL.dll
webp.dll
Xbmf.dll
Xcompound.dll
Xeri.dll
Xfif.dll
Xfpx.dll
Xiwc.dll
Xjbig.dll
Xjng.dll
XMrSid.dll
Xp2.dll
Xpax.dll
Xpwc.dll
Xsff.dll
Xwhypic.dll
Xwic.dll
Xwlm.dll
Xwmp.dll
Xwsq.dll
zlib1.dll Code: Select all
7z.dll
cacert.pem
FIPL.txt
Flash.lng
Flash.xnp
FreeImage.dll
FTP.lng
FTP.xnp
id3lib.dll
libcurl.dll
libdsw-1.1.0.dll
libeay32.dll
libmcl-6.0.1.dll
libmpg-2.4.0.dll
libogg-2.1.0.dll
libquant.dll
libquant.txt
libwmv-3.0.1.dll
Masks
Microsoft.VC90.CRT
NeroCD.lng
NeroCD.xnp
packJPG.dll
PackJPG.lng
PackJPG.xnp
Paint.lng
Paint.xnp
PhotoMasque.dat
PhotoMasque.lng
PhotoMasque.xnp
pngout.exe
PNGout.lng
PNgout.xnp
Riot.dll
Riot.xnp
riot_changelog.txt
riot_license.txt
sqx20.dll
ssleay32.dll
UNACEV2.DLL
unrar.dll
Unzip32.dll
xmp.dll
Zip32.dll
ZIPPack.lng
ZIPPack.xnp
zlib1.dll -
Try to move openjp2.dll or webp.dll?
jgh
Renamed webp.dll to ~.dl$, problem has gone away XnView now starts without error.
Just wondering what it was for - it didn't show up in plugins information, so I hope I don't need it.
Anyway, thanks - merci.
- Forum Librarian
This I/O plug-in adds read and write support for the WebP file format to XnView.jgh wrote:Renamed webp.dll to ~.dl$, problem has gone away XnView now starts without error.
jgh
Downloaded and unzipped that webp.dll, and copied it to plugins folder, problem has not recurred.
But I notice that that version of webp.dll is not the same size (and date) as the version which came with the XnView 2.40 (Extended) that I downloaded and installed, and that the version in the 'all plugins' zip file is different from both! - I would have expected them to be all the same.
michelg77
too complicated to read, too long. Headline needed : rename webp.dll webp2.dll
Qastet
Version 2.43, WinXP, the problem remained. The decision from jgh helped, but it's inconvenient: I advise you to include the library webp.dll in the distribution.
- Forum Librarian
Please download and install the Visual C++ 2013 runtime libraries:
XnView-User
The same applies to me on my Windows 7 64-Bit system. I upgraded today from Xnview Full-Version 2.40 to Xnview Full-Version 2.42.
But with this current Version 2.42 I get the same error message saying that “MSVCR120.dll is missing” when starting XnView.
Strangely, after clicking on OK XnView will start even though.
I immediately rolled back to Version 2.40 because I didn’t have this annoying bug before with Xnview Full-Version 2.40.
And what is written here about installing Visual C++ 2013 doesn’t seem to me relevant because all previous versions of the past years ran smoothly on my system without(!) this Visual C++ 2013. I have other Visual C++ versions installed o my system (please see screenshot)
For me this issue is nothing but a bug in the current Version 2.42. It would be great if you could fix this. Thanks.
Using: XnView Classic on a Windows 7 64-bit system and XnView MP on a macOS and Windows 10 system.
- Forum Librarian
“What is written here” is relevant because MSVCR120.dll is part of the Visual C++ 2013 (v12.0) redistributable package but isn't included in earlier (2005, 2008) or later (2015) versions.XnView-User wrote:And what is written here about installing Visual C++ 2013 doesn’t seem to me relevant because all previous versions of the past years ran smoothly on my system without(!) this Visual C++ 2013. I have other Visual C++ versions installed o my system (please see screenshot)
webp.dll is used by XnView for loading and saving WebP files. To my knowledge, it's the only component of XnView to rely on MSVCR120.dll. Previous versions of webp.dll didn't need MSVCR120.dll, but they were not compatible with Windows XP.
You've got four options:
- Install the Visual C++ 2013 runtime libraries.
- Replace \Plugins\webp.dll with an earlier version.
- Remove webp.dll from the Plugins sub-directory of your XnView installation (which deactivates support for WebP).
- Ignore the error message and continue to use XnView without support for the WebP file format.
XnView-User
Thanks for your answer.
Listen, I’m just a user and not a programmer. Therefore I don’t have a clue what all this Visual C++ stuff is and for what I need it. I also didn’t install this Visual C++ stuff, it came preinstalled on my system and probably with other software installations.
But one thing is for sure:
The here described error came up, on my system, only with Xnview Full-Version 2.42.
Xnview Full-Version 2.40 doesn’t have this error! Version 2.40 starts without this error on my system and that’s the reason why I rolled back to it. And furthermore: All other previous XnView versions from the last years (I’am talking about many years that I use XnView) didn’t have this error as well!
What you are telling us here about Visual C++ and webp.dll files is just very confusing to me, far too confusing for normal users. For me the simple question is:
If XnView suddenly needs this Visual C++ 2013 thing to work properly, why doesn’t it come along with the installer?
Anyway; I choose option number five, the by far easiest solution to this problem:
I will just stick to Xnview Version 2.40
