Any plugin or solution to view smartdraw drawings ?
Cmag
Post by Cmag »
Xnview is greeaaaaaaattttt !
I was just wondering wether there exist a plugin to view smartdraw (v7) drawings with extension sdr ?
I saw support for smardraw 6 templates (sdt) in the supported formats but nothing for the drawings.
Thanks a lot.
Chris
Re: Any plugin or solution to view smartdraw drawings ?
Cmag wrote: Xnview is greeaaaaaaattttt !
Thanks, the sdt support is not a full support. Could you send me a sdr sample, please?
Post by Guest »
Hi Pierre,
The sample is in the box !...
C.
