"Open only one view for multiple files" problem
xnviewquestioner
Post by xnviewquestioner »
4 years ago another person asked the same question regarding this problem but his solution didn't work for me.
I will use almost the same words he used to formulate my question below:
"In XnView 2.40, in Tools>Options>View I have checked - "Open only one view for multiple files (startup & drag-drop)". When I drag-drop a file into XnView it does correctly open that file in a new tab. But when I double-click a file from Explorer - it always opens that picture in a new window even if an existing window is already open. So if I open x files from Explorer, I get x separate windows of XnView.
When launching a file from Explorer, It should detect if XnView is already open and open that picture in a new tab in the same window."
The solution:
Tools>Options>General - "Only one Instance" checkbox ticked didn't solve the problem!
My operating system is windows 10 x64.....
Re: "Open only one view for multiple files" problem
"Open only one view for multiple files (startup & drag-drop)" is not for that. If you drag&drop muliples files, only one edit view is opened (next/previous used to browse file list).
if you use "Only one Instance", You'll have only ONE XnView, and multiple tabs
xnviewquestioner
xnview wrote: Wed Aug 09, 2017 12:23 pm
I'm sorry for the extreme delay in response, I've totally forgot about opening this topic probably due to circumstances.
However I did select "Only one Instance"!
Look at the screenshot please:
For years now Xnview doesn't open in the same window tabbed.
What's the problem with 'Double Click'......, maybe a bug?
