Auto go to current folder?
DummyPLUG
Post by DummyPLUG »
If I open a photo directly from windows explorer it will launch the viewer first, then when I switch back to browser the "Folders" list will be all collapse, is it possible it will go to the folder which the photo locate automatically? So I don't need to manually browse through the "folders" list to find it, good for if I want to move some photos from there to other location
p.s. or button/shortcut that will go to the folder (in the folder list) where the photo locate?
Re: Auto go to current folder?
by default, the current folder is opened. Is it a file on network drive?
DummyPLUG
Post by DummyPLUG »
xnview wrote:by default, the current folder is opened. Is it a file on network drive?
Yes it is, on a smb share
for network drive, you can add in xnview.ini [%General] section
expandUNC=true
