Indexing, tagging and CPU/MEM usage question
flips
Post by flips »
Hi! Running 0.86 on macOS 10.12.6, quite new i5, 8 GB RAM, SSD drive.
I'm organizing quite a lot of photos in batches.
If I enter a directory with 400+ photos, XnViewMP uses quite a while just processing it.
Then when I do select all and change/remove/add categories, it's left working for quite a while, seemingly unresponsive. (Shown as "Not responding in Activity Monitor".)
This is not unexpected and probably quite OK.
My question is:
Is there a rule of thumb/recommendation of max number of JPEGs (3264x2448 pixels) per folder? :?: :D
So far I've a few folders with 300-650 photos in each.
(Oh, and some of the photos are on a CIFS/SMB share.) :o 8)
flips 8)
Re: Indexing, tagging and CPU/MEM usage question
flips wrote: If I enter a directory with 400+ photos, XnViewMP uses quite a while just processing it.
Your pictures are in jpeg? Are you saving categories in XMP metadata?
flips
Post by flips »
xnview wrote: Your pictures are in jpeg? Are you saving categories in XMP metadata?
Yes, JPEG's, storing categories in XMP, not sidecar files. :)
flips 8)
so when changing categories, i need to edit the metadata of all your files, this can take long for many files
how long is it?
flips
Post by flips »
xnview wrote:so when changing categories, i need to edit the metadata of all your files, this can take long for many files
how long is it?
I think it froze/worked for 2-4 minutes when there was about 500 files to process.
I was thinking maybe there's a rule of thumb/recommendation for files per directory ... :?: :)
flips 8)
flips wrote: I was thinking maybe there's a rule of thumb/recommendation for files per directory ... :?: :)
The number of files per directory is not the problem, the problem is the number of files that you want to update by changing categories/rating/...
flips
Post by flips »
Makes sense ... so I should limit that to batches of ~50 files?
flips 8)
flips wrote:Makes sense ... so I should limit that to batches of ~50 files?
yes better
flips
Post by flips »
I think I'll split each dir into Months as well as Year, and it'll be ~50 in each ... :)
flips 8)
