Unnecessary image recoding
two_legs
Post by two_legs »
I am removing metadata (the only action) from JPEG files. My target format is As original. The problem is that XnConvert recompresses JPEGs. This is not the case in XnView.
If only non-image changing Actions are selected and output format is As Original, the image data should be copied without recoding.
Re: Unnecessary image recoding
yes currently it's a known issue, you need to use XnView Classic or XnView MP
two_legs
Post by two_legs »
XnView MP left this in my folder (but right, images are not re-encoded):
so I guess I'll just use exiv2
two_legs wrote:Hello,
please check Settings>General>File operations
