PSD thumbnail is pixelated. Possible improve quality?
cadu
Post by cadu »
I'd appreciate help. Using XnViewMP 0.87_3.
As showed in the snapshot below, PSD thumbnail is pixelated in comparison to JPG. Thumbnails from JPG a high quality, and I'd like better quality for PSD too. Is it possible? How to?
Thanks,
Carlos
https://i.imgur.com/4WslNwX.jpg
Re: PSD thumbnail is pixelated. Possible improve quality?
perhaps the embedded thumbnail is small, do you have the setting Thumbnail>Create from original if...
cadu
Post by cadu »
Thanks for reply!
The setting "Thumbnail>Create from original if..." seems that's not working for PSD files.
The only way PSD thumbnail improved was after unchecking "Use embedded thumbnail".
However, this global change affects DNGs thumbnail, which becomes "black" after rebuilding them.
Then to have PSD great thumbs causes DNG thumbs issues (and vice-versa)
I recorded my screen showing the issue in details: https://goo.gl/UZTXVg
Any workaround to have both PSD and DNG with great thumbnail quality?
cadu wrote: Any workaround to have both PSD and DNG with great thumbnail quality?
could you send me a DNG & PSD?
cadu
Post by cadu »
You can access the DNG & PSD files here: https://1drv.ms/f/s!Aicp80bKqtj9ogQ4VforjrLbRSIe
right :arrow: Reproduced
See issue for current status and some details. I'll post here once the problem has been fixed.
This problem is supposed to be fixed in XnView MP 0.90. Please check and confirm the bug fix here.
