No preview and no info data
I work with XnViewMP 0.87 64bit on a Windows 7 system.
When I click on a folder, that contains sub-folders and images, XnViewMP selects the first available image, but it does not show a preview and it does not display the info data. See attached screenshot.
Same happens when I start XnViewMP with this folder to open.
Clicking on a folder that contains only images, the first image is selected and both preview and info data are displayed
Best regards
Herb
Best regards
Herb
Re: No preview and no info data
Hello Pierre,
The behaviour is not only at start of XnViewMP; it is always when I click on a folder that contains subfolders (and also at startup).
As you can see in screenshot: For the subfolders 4 thumbnails are created and for each image file the thumbnail is also created;
BUT: no preview and no info data.
Best regards
Herb
Best regards
Herb
and you hadn't this problem with 0.86?herb wrote: The behaviour is not only at start of XnViewMP; it is always when I click on a folder that contains subfolders (and also at startup).
Hello Pierre,
yes, the problem is new with version 0.87.
I never had it with version 0.86.
Thanks for your investigations.
Best regards
Herb
Best regards
Herb
This problem is supposed to be fixed in XnView MP 0.88. Please check and confirm the bug fix here.
This problem is supposed to be fixed in XnView MP 0.89. Please check and confirm the bug fix here.
