[Subsidiary] Custom colours are lost…
:arrow: Pierre & All
:) Hello !
- From the Options, set any custom colour in the Win-palette, let's say for the «View» window background…
- Close the options…
- Come back to the same colour choice, call the palette : your customized colour has gone :(
- Although it's a usual behaviour of Win 9x, it's possible to improve this in the program, since it's done in another viewer. Below, a piece of codes which is used in this viewer (from its author himself, and free to use) :
—Image
- It should be great to keep the customized colours, this'ld avoid me to yell when bound to reset the same colours endlessly… :P
:mrgreen: Kind regards,
ouistiti
Post by ouistiti »
2 Clo
Same behaviour here with an "XP" machine... :(
Friendly
Paul
1,77245385090552... •
Re: [Subsidiary] Custom colours are lost…
Clo wrote::arrow: Pierre & All
:) Hello !
Yes, right. Currently customized colors are not saved...
ouistiti
Post by ouistiti »
2 Pierre
Do you think that could be fixed in a future version? It's really irritating… This works fine in Uniview under XP, like you can see below :
I guess it's this program that Clo is talking about ?
Friendly
Paul
Palette still…
:arrow: Ouistiti
:) Hello Paul!
- Indeed, it's in Uniview… Not a competitor really, since designed for freeware personal use only, and too because the program development is pending (the author has his university studies to end…).
- Below, the palette I get under Win 98 SE in that program:
————Image
- This is got as well for the Options (background colours…) as for the painting retouch-features, where it's more important… ;)
:mrgreen: Friendly regards,
