XnView MP Linux
Version 0.87 64bits (Sep 5 2017)
Libformat version 7.10
Xubuntu 16.04 LTS
I'm using the Fusion Dark theme and until just lately it's been fine. A few days ago, all my thumbnail labels turned black. They're set to white on black, but nothing I do will make them appear in any color than black. I've lightened the thumbnail cell color to a medium grey so I can read them, but that's only a temporary workaround.
I'm getting frequentOS/app updates from Ubunutu, etc., so yes it's updated on a regular basis, but I've been at 0.87 since before this started. I'm not sure what UI toolkit XnView uses in my case (QT, GTK, etc.), but I guess it's possible a config file could've been touched (although I didn't do it explicitly).
Otherwise, everything is perfectly functional. Any idea of what's causing this?
Thanks!
Thumbnail labels are always black
lphilpot
Len Philpot
Re: Thumbnail labels are always black
XnView use QT, you have not changed your settings?
lphilpot
Not that I know of. Since leaving KDE for Xfce, I have very few programs using QT and I've not specifically changed anything.
Len Philpot
lphilpot
Hate to resurrect an old thread, but this is still happening. I'm currently on 0.98.4 64 bit, Xubuntu 18.04 LTS, using the Fusion Dark theme. Here's what I see:
The foreground / background setting for the labels has no effect. As before I've set the thumbnail cell background to a medium grey to make the black labels visible (otherwise they're black on black).
I've made no QT changes and I can't find anything in XnView where I can correct this. Is it something in the theme that's overriding?
Thanks.
Thanks.
Len Philpot
ok, i can reproduce if you don't use 'use color format based on file format'
lphilpot
Getting closer!
It seems logical that if file format colors are disabled, the label default should take over. Bug?
At any rate, I don't care about format colors, so I'll just set them all to the same color and use them. But even so, when there is a third line on the label it (File: {Modified Date [Y-m-d H:M:S]}) is still getting rendered in black. Is there another setting I'm missing?
Also, it appears I've uncovered a bug, confirmed it three times. Open Preferences, go to Browser | Thumbnail | Appearance, click the cell background color picker, swipe and copy (Ctrl+C) the color value. XnView hangs hard and I have to kill it off.
I haven't tried the foreground picker but it doesn't hang on the label background picker. I'm running Version 0.98.4 64bits (May 31 2021) Libformat version 7.81 on Xubuntu 18.04 (patched).
Thanks.
Thanks.
Len Philpot
