Brower image dimension different from viewer's
homansang
Post by homansang »
I tried to crop and resize an image. Afterwards, the dimension in mm or in inch (width x height) of the image in the status bar is different between browser and viewer. The pixels are correct and are the same between browser and viewer. FYI, the dimension in the info pane is correct. I thought it's probably a bug. Or do I mis-understand about the dimension shown in the browser?? Is it related to crop and resize??
Thank you.
Re: Brower image dimension different from viewer's
could you send me it?
homansang
Post by homansang »
Are you able to determine whether it's a bug or not?? Or did I just do something wrong??
Many thanks.
homansang wrote:Are you able to determine whether it's a bug or not?? Or did I just do something wrong??
I can't reproduce, i have the same text in viewer & browser
homansang
Post by homansang »
Talked with Pierre and seems that it's a problem with embedded thumbnail. Should be able to fix too.
Many thanks.
