Import dialog: add options "file picker" + "delete imported items"
cadu
Post by cadu »
The only functionalities I miss in the "import and sort" dialog are:
- FILE PICKER, showing the thumbnails of images in order you can choose just those you do want to import.
- DELETE IMPORTED ITEMS, having a checkbox you may choose if you don't need the media in the source anymore.
It follows below a snapshot of the Windows 10 Photo app, which has both functionalities. I saw it in ACDSee too.
Thanks for considering it.
Carlos
cadu
Re: Import dialog: add options "file picker" + "delete imported items"
Post by cadu »
In the following thread there are arguments for not providing option for delete after importing, since some problem can happen in destine, and if files where also deleted from source, then a mess is settled. So if the user wants, after importing, just format the card.
https://forums.adobe.com/thread/937225
What do XnView users think about it?
"file picker"
This is still a must have feature IMO
