Image not showing in input window
Ali041
Post by Ali041 »
I'm using XnConvert for quite some time, but now there is an issue, possibly after updating to OS High Sierra.
I use the application in conjunction with the export function in Adobe Lightroom; in this function you can define an application to automatically open after the exporting is done, in this case xConvert.
Normally when xConvert opens, you see then the image-file appear in the input window. But now the windows stays empty.
I think I have seen this phenomenon in the past. After an update it was solved, however I cannot recall when.
The same happens when you right-click on an image in the finder and select open with … XnConvert.app; the input windows also stays empty.
I completely removed XnConvert and installed it new, but problem is still there.
Any ideas?
PS: Drag and drop works fine, but that's not the way I use it.
Re: Image not showing in input window
i can't reproduce on Sierra (not high sierra), you have the problem even if you drag&drop image files on XnConvert icon?
Ali041
Post by Ali041 »
Thanks for the reply!
No drag/drop works fine
regards,
Arno
is it the version from apple store or from my website?
Ali041
Post by Ali041 »
It is the latest version from the website.
I have to correct my previous answer:
I can drag a picture the input-window of the opened XnConvert application.
I'm not shure what happens, when i drag a image on the XnConvert icon; I will let you know tonight.
regards,
Ali041 wrote: I'm not shure what happens, when i drag a image on the XnConvert icon; I will let you know tonight.
yes please
Ali041
Post by Ali041 »
Hello Pierre,
When I drag the image on the icon, XnConvert opens. However the input-windows stays empty.
Ali041
Post by Ali041 »
Hello Pierre,
I completely removed the application and now installed it from the app store instead.
This time it is working like before!
Don't know what the problem was, maybe something with permissions or trusted website?
Kind regards,
Arno
