Editing EXIF Data?
scan95
Editing EXIF Data?
Post by scan95 »
Is it possible to edit EXIF data with the latest release? For example, the date set in my camera was wrong when a photo was taken: is it possible to change the "date picture taken" data?
Re: Editing EXIF Data?
scan95 wrote:Is it possible to edit EXIF data with the latest release? For example, the date set in my camera was wrong when a photo was taken: is it possible to change the "date picture taken" data?
You can edit IPTC data with XnView, but currently not EXIF data or EXIF date.
There have bee some requests to add/subtract a specific period to the dates (for example for the case that the cameras time was not adjusted to the appropriate timezon). From what I can read in the related posts, there's a plan to support editing the EXIF date in the next release.
Related posts:
- Editing exif not possible?
- Décaler la date (French)
Post by Guest »
No, it's currently not possible.
But try jhead for this task. It shows its full power with batches/scripts on several images.
I'll add this feature soon...(only for date)
