problem on browsing some directory
viewer
Post by viewer »
Hi, I find a bug(?) under the explorer of xnview.
this problem is asisan character OS specified.
My OS is WinXp SP2, here I will explain the problem with some
traditional Chinese.
If a name of a directory ends up with the traditional Chinese character
"聚" , it can not move to upper directory after get in.
Post by Guest »
my xnview version is: 1.80.3
viewer
Re: problem on browsing some directory
Post by viewer »
viewer wrote:Hi, I find a bug(?) under the explorer of xnview.
or the character "餐" Sorry I was a little confused.
