0.87: "Full row select" disappeared?
phaolo
Post by phaolo »
XnView: MP 0.87 64 bit
OS: Windows 7 Pro 64bit
What happened to the option "Full row select"? (in Browser>File list ?)
It was a feature I requested and it worked till v0.86 :(
Effect: in details view I can't select multiple files directly with the mouse, or I can't open the menu (e.g: to paste files) directly in a folder, etc..
1. set the details view
2. try to do what I descibed above
Actual behaviour (bug): move files, show file menu :bug:
Expected behaviour: select files, show folder menu
Re: 0.87: "Full row select" disappeared?
i don't understand the problem, could you post a screen capture?
phaolo
Post by phaolo »
Here is a link to an old thread, otherwise I'll have to explain everything again:
viewtopic.php?f=35&t=32573&p=130678#p130678
You can find the screeshot there.
phaolo wrote:Here is a link to an old thread, otherwise I'll have to explain everything again:
?? it's the same in 0.86
phaolo
Post by phaolo »
xnview wrote:?? it's the same in 0.86
Are you sure? O_o
I'm confused..
Did you add such feature only in Xnview classic?
Are you sure? O_o
I'm confused..
i didn't remember to have added that in XnView MP
phaolo
Post by phaolo »
Uh.. then, could you add it? Please? :? :mrgreen:
