0.87: Browse mode preview shows alpha channel when it's disabled
yochenhsieh
Post by yochenhsieh »
XnView: MP 0.87 - 64-bit
OS: Windows 7 - 64-bit
Effect: Browse mode preview shows alpha channel when it's disabled.
The preview window in browse mode shows alpha channel when it's disabled, and don't show alpha channel when you enable it.
1. Browse image files with alpha channel (TGA format).
2. Select a image file.
3. The preview window shows alpha channel by default.
4. Right click on the preview, you see the alpha channel is disabled. Enable it.
5. Notice alpha channel on preview is disabled after you enabled it.
Expected behaviour: preview shows RGB by default, or at least disable alpha channel when you disabled it.
Note: no matter you disabled alpha channel or not, the next session alpha channel on preview always shows in browse mode.
