When browsing between folders using "Data Pane" in "Browser view" - the browser usually automatically selects the first image in that folder.
The image preview/properties etc is not shown in the "info pane" (need to select another image, then re-select the image)
In fact the info pane "flashes" the preview and then blanks the "info pane"
Version 0.87 32bits Win10
Initial (automatic first) selection not showing in Info pane
xiofen
xiofen
Re: Initial (automatic first) selection not showing in Info pane
Thanks - seems fixed in 0.89
