Portable PDF Support
leminsc8
Post by leminsc8 »
Iam Worrie about that i cant view PDF with XnViewMP (x64) PORTABLE.
I find the Ghostscript Info to install that but i can't find a Portableversion of it....
i have contact Ghostscript for Portable Support. let's see what they say
mabye helpfull: https://www.ghostscript.com/doc/current ... ll_Windows
can you made a wiki-indroductionto how to made Ghostscrypt Portable on XnViewPortable Directory OR fix it in future as Plugin/Addon?
it will be verry helpfull!
greez from germany
Re: Portable PDF Support
cday ([url=http://newsgroup.xnview.com/viewtopic.php?p=145578#p145578]GhostScript portable & XnViewMP[/url]) wrote:
igel wrote:As mentioned above I'm using XnView MP portable (not the one from PortableApps but the one offered on this site - the zipped package).
It seems that there is no way to tell XnView MP where to look for the location of the portable GhostScript. Too bad. :(
The following thread describes the earlier unsuccessful attempt to enable XnView Classic to be used as a portable application with Ghostscript support:
XnView portable version with Ghostscript
