Hi.
XnView MP Linux
Version 0.87 64bits (Sep 5 2017)
Libformat version 7.10
Is there a way to set up XnView MP in a way so that when I save a file - any format that options may be adjusted - I got asked to spcify the file format options? Eg. adjusting image quality when saving as webp or jpg.
Otherwise I have to go all the way to the general options to adjust that before save file.
Thanks
Save as (webp) - options for every file
Sprintdriver
Re: Save as (webp) - options for every file
currently there is no way
Sprintdriver
update on this:
Solution for me is to export current image. That brings up the menu for quality, etc. for those formats that are supported by export feature.
