How do I change the location of the database?
doc-ralf
Post by doc-ralf »
Hi folks,
this is obviously a simple question. Sorry for not finding the correct answer in the forum:
What do I have to configure to change the location of XNView.db and thumbs.db (from AppData\Roaming\XnViewMP to the temporary directory?
Regards
Ralf
Re: How do I change the location of the database?
doc-ralf wrote:What do I have to configure to change the location of XNView.db and thumbs.db (from AppData\Roaming\XnViewMP to the temporary directory?
Tools > Settings... > Integration -- Paths tab
Onlyzen
Post by Onlyzen »
In Object Explorer, right-click on your server and click Properties.In the left panel on that Properties page, click the Database settings tab.
In Database default locations, view the current default locations for new data files and new log files.
