I'm trying to classify all my (mostly biological) fotos. So I enter the name of all living objects in the Object description.
However, when I try to search for a specified object, I can't find it with a search using the catalog. It can only be found with a full scan of all files.
How can I update the catalog, so that these pictures can be found using catalog search instead?
How to fill/update the catalog for searches
Re: How to fill/update the catalog for searches
Settings>Catalog>Add folder
doc-ralf
Yes, they are all in the Catalog
but somehow the IPCT Object description data is not in the Catalog.
E.g.: This is a typical IPTC description:
But when doing a full search, they are found - but slowy, of course.
What am I doing wrong?
If I perform a search for IPTC using the Catalog, the pictures of "Calluna vulgaris" can't be found.Objekte:
Calluna vulgaris
Besenheide
Sommerradtour 2017
Deutschland, NRW, Haltern, NSG Westruper Heide
could you send me a picture file?
