0.88 Linux. system theme not adhered
jooch
Post by jooch »
XnView: MP 0.88 / 64 bit
OS: Manjaro Linux 64bit
After upgrading to version 0.88 (needed to fix fontconfig issue) the system theme is not applied to XnView. All other QT apps work fine with the system theme. Qt5ct is set up.
Effect: Xnview will only apply Qt's default theme.
1. Install version 0.88
2. Start XnView
Actual behaviour (bug): Fails to apply system theme :bug:
Re: 0.88 Linux. system theme not adhered
i use lastest version of QT now (Qt 5.9), so perhaps a problem here
jooch
Post by jooch »
I have qt 5.9.2 installed, so your version is older? I might have a system that was not updated recently, i'll test tomorrow.
jooch
Post by jooch »
I found a laptop which still used qt 5.9.0, it also has the same problem with the XnViewmp 0.88, but not with 0.87.
QT 5.9.1 was known to have problems with theming from what i could find on the Manjaro forums, but that was back in July this year and solved with 5.9.2.
jooch wrote:I found a laptop which still used qt 5.9.0, it also has the same problem with the XnViewmp 0.88, but not with 0.87.
strange i use 5.9.2
sissou
Post by sissou »
Same on my debian system, qt 5.9.2 : XNView will only apply Qt's default theme.
Theme was fine with XNView 0.87.
sissou wrote:Same on my debian system, qt 5.9.2 : XNView will only apply Qt's default theme.
i ask QT team
is it GTK2, GTK3, KDE theme?
sissou
Post by sissou »
It's Arc GTK Theme, so GTK3 !
I use XFCE so I think it is GTK2 too ?
jooch
Post by jooch »
Tested on XFCE system and Openbox, both configured for GTK2 and GTK3.
However, as far as i know QT5ct can only handle GTK2 themes.
roland65
Post by roland65 »
I tested on the latest Ubuntu 17.10. There, I used the adwaita-qt package to match the adwaita gtk3 theme (I think there is no other way to match gtk3 themes). This worked with VirtualBox (that also uses Qt 5.9.2) but not with XnView MP 0.88, where the default Qt theme is always used.
on your system, which version of Qt do you have?
sissou
Post by sissou »
Same with qt 5.7.1 and 5.9.2
roland65
Post by roland65 »
xnview wrote:on your system, which version of Qt do you have?
This is Qt 5.9.1.
This is Qt 5.9.1.
and if you try XnView not xnview.sh to use system libraries?
