0.88 Linux. system theme not adhered
roland65
Re: 0.88 Linux. system theme not adhered
Post by roland65 »
[quote="xnview"but it's a gtk 2 theme
https://launchpad.net/ubuntu/+source/gn ... s-standard[/quote]
No, Adwaita is a GTK 3 theme. It's indeed 'the default GTK3 theme'. I guess the gnome-themes-standard package (and its associated package gnome-themes-standard-data) is a compatibility package for GTK2 applications. However, if these packages are not installed, then on Ubuntu 17.10, gnome-tweak-tools doesn't see the Adwaita and Adwaita-dark themes.
but why is it written? "GTK+ 2 versions of the Adwaita and High Contrast themes"
roland65
Post by roland65 »
xnview wrote:but why is it written? "GTK+ 2 versions of the Adwaita and High Contrast themes"
I don't know!
If you don't trust me (and I understand), just do this:
cat /usr/share/themes/Adwaita/gtk3/gtk.css
You'll get this:
/* Adwaita is the default theme of GTK+ 3, this file is not used */
roland65 wrote: You'll get this:
Adwaita, not Adwaita-dark
I've tried 'speedcrunch -style Adwaita-dark', and i have 'QApplication: invalid style override passed, ignoring it.' too
If i set Adwaita-dark, speedcrunch use it own theme :(
Do you use 'global dark theme'?
roland65
Post by roland65 »
xnview wrote:I've tried 'speedcrunch -style Adwaita-dark', and i have 'QApplication: invalid style override passed, ignoring it.' too
As I explained in another message:
I did some research on the Internet and found that starting with Qt 5.6, the system GTK theme can't be used directly, as it was the case with previous versions (indeed in Ubuntu 16.04, I used various Qt applications without any theme problem). There seems to be no global solution to this problem, except for the Adwaita theme. For this particular theme indeed, one has to install the package adwaita-qt and call Qt 5 applications with the '-style' parameter and then the Adwaita (or Adwaita-dark) theme is used by the Qt 5 application.
So, you have to install the package adwaita-qt before trying to use the '-style' parameter.
roland65 wrote:So, you have to install the package adwaita-qt before trying to use the '-style' parameter.
ok, thanks.
If you copy /usr/lib/x86_64-linux-gnu/qt5/plugins/themes in lib folder of XnView, it works!
roland65
Post by roland65 »
xnview wrote:If you copy /usr/lib/x86_64-linux-gnu/qt5/plugins/themes in lib folder of XnView, it works!
I don't have such a folder. Do you mean /usr/lib/x86_64-linux-gnu/qt5/plugins/platformthemes ?
after installing adwaita-qt, i have themes subfolder in qt5/plugins
you can search for adwaita.so?
roland65
Post by roland65 »
xnview wrote:after installing adwaita-qt, i have themes subfolder in qt5/plugins
On Ubuntu 17.10 (artful aardvark), the adwaita.so library is located in /usr/lib/x86_64-linux-gnu/qt5/plugins/styles
So I copied the directory /usr/lib/x86_64-linux-gnu/qt5/plugins/styles to /opt/XnView/lib and launched:
xnview -style Adwaita-dark
and now the Adwaita dark style is correctly applied :-)
roland65
Post by roland65 »
I found another way to get the system themes applied when using XnView 0.88. Here are the steps:
1. Download the sources of the qt5-style-plugins package (see attached qtstyleplugins-src-5.0.0.tar.gz tarball)
2. Compile the package using Qt 5.9.2 (or use the attached lib.tar.gz tarball that contains the compiled libraries)
3. Copy the 'styles' directory into <install directory>/XnView/lib
4. Copy 'libqtgk2.so' into <install_directory>XnView/lib/platformthemes
5. Launch XnView like this:
xnview -style cleanlooks
or:
xnview -style motif
or:
xnview -platformtheme gtk2
The first command will use the old GTK CleanLooks style. The second commabd will use the old Motif style (not very interesting I admit).
The third command will match *any* GTK2 theme, including the GTK2 versions of Adwaita, Adwaita-dark that are provided with the gnome-standard-themes package. Using this command I can match my custom BlueBird theme, the Ubuntu Radiance theme, etc. However, for some reason, the custom icon theme is not used, instead the default icon theme is used.
Interestingly, I found that:
xnview -style gtk2
crashes XnView. This sounds like a bug, I guess...
Of course, as you already found:
set the theme to Adwaita or Adwaita-dark if the adwaita.so library is copied into <install_directory>/XnView/lib/styles.
Anyway, perhaps you could provide the missing libraries within the next release of XnView MP? This should help Linux users to match their system theme.
lib.tar.gz
(798.3 KiB) Downloaded 66 times
(302.82 KiB) Downloaded 69 times
roland65 wrote: 4. Copy 'libqtgk2.so' into <install_directory>XnView/lib/platformthemes
and the one that i've built doesn't work???
roland65
Post by roland65 »
With version 0.88 you only provided libqgtk3.so and xnview -platformtheme gtk3 doesn't work.
i means this file
could you try to extract this file in XnView/lib/platformthemes/
roland65
Post by roland65 »
xnview wrote:i means this file
OK, it works, but only when the library libqgtk2style.so is also contained in the directory XnView/lib/styles, and when launching:
Note that, in this case the system icon theme is not used (the widget theme is used however), although it is used when launching xnview without the platformtheme option.
Note also that xnview -style gtk2 crashes XnView...
These theme issues of Qt5 are a real pain!
sissou
Post by sissou »
Anything new with v0.89 ?
On debian Stretch stable I managed to have good looking on qt5 apps (QOwnNotes, VLC) with compiling qt5ct (https://debian-facile.org/viewtopic.php?id=13593).
But it does not work with XNView...
