XNMP 0.88 on archlinux.
I screwed up, I decided to clean up my categories and start fresh.
In the category tab, there were a lot of old categories loaded from XMPs when reading the files.
I pressed the down arrow/triangle at the top from the categories panel > categories management > clear all and this deleted all the categories but...
Now I can't create new categories. No right click on the categories panel.
How can I add new ones?
Thanks
Syv
Can't add categories
Re: Can't add categories
Select at least one photo before managing catogories ...
Catalogage avec XnviewMP :
elfroggio
I did. It makes no difference. Before I deleted all categories, I was able to go into the category panel > right click and add a new category.michel038 wrote:Hi,
But when I deleted all of them, I can't. Image selected:
- Right click on categories panel: nothing
- Right click on image: the last item == category, there's a right arrow/triangle, left click on it and nothing...
Syv
In "Categories" panel, I never could use right-click without selecting an image.
In "categories filter" panel , I can right-clic on the first one "Categories", for creating a new one, but I never used it.
Which one are you using ?
View menu , Data pane You can also create a new text file, containing two lines :
cat
dog
and use the down arrow/triangle at the top from the categories panel > categories management >import category file
and import this file
cat
dog
elfroggio
Worked!michel038 wrote:View menu , Data pane
You can also create
Merci beaucoup
