0.88 stupid config at “import”
ziotean
Post by ziotean »
import - destination - new file name
Should not uncheck means "keep origin name" ? how do you think it mean "blank name".
btw, Chinese translation sucks, totally different meaning.
Re: 0.88 stupid config at “import”
could you explain me more your problem?
ziotean
Post by ziotean »
import and sort dialog-box, uncheck "New filename" means imported files name blank.
It should be original name if unchecked.
Maybe its a suggestion not a bug.
if 'New filename' is not checked, 'import&sort' will use original filename
